EXHAUST ON FIRE!!
Old Mar 27, 2007 | 10:26 PM
ebinkerd's Avatar
Default EXHAUST ON FIRE!!
how hot will the exhaust get, hot enough to glow?? rptr 700
Old Mar 27, 2007 | 10:32 PM
Raptor450's Avatar
We measured the headpipe on a Yamaha 450 one time with a lazer thermometer and it was about 550 degrees F. If your pipe glows alot, your engine is running too lean. In my experiences, the pipe will glow a little right at the head if you're running it hard on a cool night even if the jetting is about right.
Old Mar 27, 2007 | 11:42 PM
quadbart's Avatar
Bink, The answer is yes. The head pipe can get hot enough to notice a glow. Especially at night and more so with an aftermarket exhaust as they use thinner material.
If its really getting super hot where the glow is REALLY excessive then it COULD be due to a lean condition. This is an old 2 stroke rule of thumb.
With the new 4 strokes and their newer ignitions, its now also possible that excessive head pipe glow can also be due to a RICH fuel condition where your dumping so much fuel in that its still burning as its exiting out the exhaust valves causing the head pipe to glow.
So , all by itself, a glowing head pipe tells you nothing. You have to put it together with other symptoms to figure out if you have a real problem.
Cole Hadden
Jun 15, 2025 09:05 AM
Shainasmash
May 8, 2017 06:38 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
toonces
Jul 24, 2015 09:03 AM
