FPS YAMAHA WOLVERINE 450 CLUTCH KIT
Old Apr 23, 2007 | 10:49 AM
Quinn's Avatar
Default FPS YAMAHA WOLVERINE 450 CLUTCH KIT
I saw this on ebay. Does anyone have any info on this kit? How does it work? Same as epi? Comparable? It looks like a good price.
Thanks much
Old Apr 23, 2007 | 12:00 PM
ctateusa1's Avatar
This is nowhere near the amount of stuff you get in the EPI clutch kit, the springs will provide an increase in accelleration from stock but that is the only thing that might give any kind of an increase. I would go with the EPI kit because it also gives you the larger spring as well and the new bushings for the primary clutch.
The FPS kit looks like a knock off just providing you with the smaller springs from an epi kit.
Old Apr 23, 2007 | 02:28 PM
miassmaro98's Avatar
yeah ive look at this to,also kit includes carb needles or jets to help out along with the clutch kit
Old Apr 23, 2007 | 03:37 PM
ctateusa1's Avatar
There is no need to rejet if all you are doing is a clutch kit.
Take a look at the difference between the EPI kit and the FPS kit
EPI clutch kit pics
pic 007 shows the bushings included
pic 008 is the blue secondary spring
pic 014 is the difference in the factory springs and the epi springs.
I personnally would feel better paying the 189.99 for theEPI clutch kit than paying 112.00 for the knock off kit that only gives you the smaller primary springs with no upgraded bushings and no larger secondary spring.
Old Apr 23, 2007 | 04:08 PM
u1arunit's Avatar
Yep it's a cheap kit with less parts and probably doesn't work nearly as well.
Old Mar 9, 2009 | 07:15 PM
dan kraeleman's Avatar
dude i have an 07 wovy and would like to know how wide your front tires are are they the same as the rears i just bought a set of itp rims that are 10 inch wide on all fours but i ordered terra cross tires that are 25x10x12 rears and 25x8x12 i am not sure if it will look dumb
Old Mar 9, 2009 | 08:01 PM
dude whats the deal who ported your head and are the cmp racks any good
Old Apr 21, 2009 | 03:47 PM
Trad1983's Avatar
Thumbs up FPS not so bad...
Just recently bought said FPS clutch kit off e-bay. Came with a jet as well. Not as easy to install as described, had to have professional install. It took about 4 mph off my top end...but you talk about get there! Can pull a wheelie from a dead stop now too with a little standing throwing your weight back, but it wasn't even an option before. In my opinion it didn't accelerate evenly or very fast through the power band to begin with. Now it accelerates hard and fast evenly from 0-45 then tails off for the last few mph's. Great money spent in my opinion
Old Apr 21, 2009 | 11:11 PM
chevy68's Avatar
I found the best bang for the buck is the hauck machined sheave.... I tossed my epi in the garbage.... had bad luck with it, springs being too stiff and not engaging my wet clutch all the way causing them to burn out..... replaced the wet clutches and everything in there and had the sheave machined with their weight kit ( rollers) and I love it...I can wheelie with my *** on the seat now. and all my top end is back..... pulls much harder all the way through....
by the way, i also hated the cmp rack.... i broke mine in three spots third trip out.... and it sticks off the back to much... just my two cents..
i found a brand new aluminium yamaha one on ebay for 50 bucks(very lucky on the price) there 122 new from a dealer...i will try to take a picture of it if you want....
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
