I WANT A NEW ATV
I WANT A NEW ATV
Just say no to the Prairie 360. The one I have it actually a royal pain in my ***. Its sucks tryin to get started, and when you do get it started....it will die. I tool around with the choke and get it running, but 5 seconds later it dies. My yamaha doesnt do that, I start it, set the choke and walk away its ready to ride when I am set to go.
#16
I WANT A NEW ATV
well kid im 17 and about 150 lbs. i just bought a 07 grizzly 400 with itp wheels and 26" itp mud light tires and i do alot of mudding and trail riding too... i have no problems i dont get stuck anywhere and i had this buried in mud... nothing i couldnt get myself out of... mine is still under the break in period and i had it doing 45 mph, keep in mind that wasnt full throttle... when you first get it it will feel a little sluggish but after you start riding it will feel like its gaining power.... good luck on your decision and oh ya i would stay away from honda personally i dont like them they dont have nearly as much ground clearance as yamaha's do... and if your doing serious trails like i am then you need it...
#17
I WANT A NEW ATV
well i'd have to say, comen from a 80cc to a 3-400. is a big jump. but i recommend it. being your 95 pounds any 4x4 is going to through you around, and give you a realy good ride. got the 350 bruin . it's now called a 350 grizz. it's the cheapest bang for your buck. it will not do wheelys bud it likes mud and doughnuts. it will do mid/high 40mph. with stock parts. i got a set of 26x10x12front/ 26x12x12x rear. and it dose about 44ish. on flat. with some little mods you can make it have a lot more low end once you get used to the stock ride. and yes it will do very well in mud and high water. got a picture on my profile if you want to see it stuck. my buddy took it out in it! trust me it was worse then it looked! only thing i didn't like about the bike is it had a rev limmit in revers. that sucked with the tires. but if you ever get one i'll tell you a way to get rid of the limmiter! later
#18
I WANT A NEW ATV
Well iam 17 230lbs and I ride a sportsman 700 which would be to big for you I think , but i had a kodiak 400 and it was good other than I got stuck quit a bit where others in the same class wouldnt , but its a good 4wheeler and i wouldnt keep polaris out of the question , the newer ones are just as reliable as anyother besdies honda they last forever.
#20
