Maier or Fullbore
Old May 1, 2007 | 07:01 PM
Comly9696's Avatar
Default Mair or Fullbore
I am buying new palstic for my 2001 660 Raptor. I am going with orange and like to know whats better fullbore or maier. Thanks
Old May 1, 2007 | 08:55 PM
Raptor450's Avatar
Default Maier or Fullbore
Fullbore.
Old May 1, 2007 | 09:45 PM
Blud686's Avatar
I just picked up a set of Maier, doesn't seem like they put a whole lot of care into it, all the trimmed edges are pretty rough. but for $250 of ebay i'm thinkin it was a pretty good deal so far, should have it installed in a couple days i'll let you know how it fits.
Old May 1, 2007 | 10:39 PM
54warrior's Avatar
That's an easy question. Fullbore. Maier looks nice at first, after you get done drilling all of your own holes to install it, hoping it lines up correctly and sanding down all the sharp edges.
You won't be disappointed with the fullbore.
Old May 1, 2007 | 10:51 PM
MasterRaptor's Avatar
Do not get the maier no matter what. It sucks! You don't get the air flow to the radiator, so it runs hot, they use cheap inch screws instead of metric, the battery does not secure becasue the compartment is too large so the cables break and come loose, there is inadequate mounting of the starter relay, there is incomplete modling in some areas that crack, crappy mounting tabs, it scratches easy, cheesy radiator access, it don't fit very well. I could probably think of more reasons. It only looks good for 3 rides. Not worth it!
Why not go with the stock plastic? There are dealers that sell a complete set for like $429 on ebay. Yamaha of Troy, I think. This is the best quality. It will keep the value up.
Old May 2, 2007 | 11:46 AM
Comly9696's Avatar
I want to go with orange plastic so I have something different from all the factory Raptors. Thanks for the info everybody. Fullbore it is!!
nachop
Feb 14, 2018 06:57 PM
54warrior
16
Dec 19, 2000 12:39 PM
collegefunded250
Nov 2, 2000 09:11 AM
88trx310R
Aug 17, 2000 10:39 AM
TrxR
Jan 30, 2000 12:52 AM
