Kill switch
Old May 2, 2007 | 04:01 AM
apny2nv's Avatar
Default Kill switch
Any one know how to install a Pro-Design Kill switch on a 03 Raptor. I know one is ground but need to know where to connect the other wire.
Thanks.
Old May 2, 2007 | 06:55 PM
apny2nv's Avatar
Default Kill switch
Anyone?
Old May 2, 2007 | 10:19 PM
recon99's Avatar
Default Kill switch
The other wire can be spliced in with your coil source wire. It'll probably be an orange wire. Make the connection good, solder and shrink-wrap it.
Old May 3, 2007 | 02:53 AM
apny2nv's Avatar
Default Kill switch
Thanks for the info.. Now is that the wire that feeds the coil? Recon... I see that you have Burgard arms... How are they? How do they compare to Houser, LSR, Etc... Are they priced right? I just bought a +1 steering stem to clear my IMS 5 gal tank. The price was great. $200 and includes the Anti-Vibe clamp. If they arms are a good price I might buy them..
Old May 3, 2007 | 07:46 AM
recon99's Avatar
Default Kill switch
Yeah, the small wire that feeds into the coil, not the big one going to the plug.
The burgard a-arms are good for the price. They're probably not on the same level as Houser and Lonestar, they're more on the level of cheaper stuff like ASR. The only reason I chose them is because Burgard is a local company, and works closely with the powersports shop I go to for testing new products and stuff like that, so I got them for $350, about $100 off the regular price. The only complaint I really have about them is that you need to ream out the spindles for the bigger ball joints. The shop did it for me for $15, but the spindles are steel unlike most which are aluminum, and it nearly destroyed a drill and $100 ream bit.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
