1998 Blaster Mix Oil Delete?
Old May 9, 2007 | 07:05 PM
Holeshot4TW's Avatar
Default 1998 Blaster Mix Oil Delete?
I bought a 1998 Blaster & the wires green & black are disconected by the rear oil tank. The guy said he just mixes it in the gas tank 20/1
But theres oil leaking out of the brake side black hose going to the motor & also oil leaking out of another clear rubber hose same side more to the middle?
What should i do to stop these leaks?
Also the rear brakes dont work???? Thanks
Old May 9, 2007 | 10:07 PM
JLsparky7's Avatar
You need to buy a blaster oil blockoff kit. Follow the directions on it and it will solve your probs.
The brakes on all the blaster older than 2003 have HORRIBLE brakes. I dont know how they were allowed to manufacture them legally. I would reccomend a rear hydraulic brake and upgrading to banshee spindles/hubs/brakes up front.
20/1 is WAAAAAAAAAAAAY to rich. It will just burn a hole in your pocket and foul plugs. Most people run 32/1 with yamalube. With a good quality synthetic you can accually run 40:1. This year I will be running 50:1 with my banshee using amsoil interceptor.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Slagpolaris
Sep 5, 2015 09:41 PM
dwhipper61
Aug 29, 2015 05:47 PM
