Raptor wont stay on
Old May 25, 2007 | 02:43 PM
natedawgls's Avatar
Default Raptor wont stay on
since i took the baffle out the other day the 660 wont stay at idle it shuts off
it stays on when choked and it rides fine when choke is off as long as i keep on the throttle a bit but if a get off and leave it to idle it shuts off
Old May 25, 2007 | 03:28 PM
toddmh's Avatar
anytime you change anything in the exhaust ..you must rejet your carb..Why did you take it off anyway??try to adjust the idle screw on the bottom of your carb,thta may help..
Old May 25, 2007 | 04:21 PM
lucasislight's Avatar
you are running too lean, you need to richen your idle and probably rejet both your carbs richer as well. when you pull your choke on it richens up the circuit, causing it to run better.
Old May 25, 2007 | 07:28 PM
velocyraptor's Avatar
BUT dont use it with the choke on
Old May 28, 2007 | 05:42 PM
beaty's Avatar
i dont no why your having proplems iv take the baffle out of two 660s and they run fine
bmxatv10
Oct 14, 2022 06:23 PM
Johnny Mac
Aug 15, 2019 03:13 PM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
black_thunder
Sep 22, 2015 07:59 PM
