07 wolverine performance parts?
Old May 31, 2007 | 06:25 PM
YamahaWolverine350's Avatar
Default 07 wolverine performance parts?
what are some performance parts i could put on my wolverine?
Old May 31, 2007 | 06:53 PM
ctateusa1's Avatar
epi clutch kit, gytr pipe, hmf pipe, dynojet jet kit, k&n air filter, or uni filter.
That is about the extent of what is available at this time I believe.
Old Jun 1, 2007 | 08:31 AM
THANKS
Old Jun 1, 2007 | 12:49 PM
ctateusa1's Avatar
not a problem
Old Jun 1, 2007 | 02:57 PM
Deviltrigger1's Avatar
Does the clutch kit make it quicker? and does the air filter give it more power?
Old Jun 1, 2007 | 04:05 PM
ctateusa1's Avatar
you might notice a little more power with the air filter. the clutch kit, will make it accellerate quicker, but you will lose top end speed.
Old Jun 2, 2007 | 04:24 AM
oh...What would the jet kit do?
Old Jun 3, 2007 | 09:11 AM
miassmaro98's Avatar
correct the fuel mixture with the added performance filter ,also there sell pistons and cams and a cdi box that should had been out but bmp takes there time
Old Jun 3, 2007 | 08:47 PM
toddmh's Avatar
I heard from somewhere,I forget..You do not need a whole clutch kit but just the stiffer springs..saves a bunch of $$
Old Jun 3, 2007 | 09:21 PM
Yamahaman06's Avatar
well the fps kit i got for mine was just the springs but it also came with a jet kit for the carb. both work flawless and give you a snappy throttle response but i loss 2 mph off the top end. but getting up to 30-40 mph quicker is worth it. hth
