Help with wolverine carb
Old Jun 7, 2007 | 12:21 PM
nucca's Avatar
Default Help with wolverine carb
I have a 2000 Wolverine and it is low on power on the low end. Once it gets revved up it has power. I have cleaned the air filter and carb including all of the jets. The diaphram that pulls the slider and needle up seems to be working. The diaphram isn't cracked or torn. I haven't adjusted the valves yet that is next. Any advice?
Old Jun 7, 2007 | 12:44 PM
buckaroo50's Avatar
Problem: Idling or low speed impaired
Condition Remedy
1. Slow jet obstructed - loose 1. Clean - tighten jet
2. Slow jet outlet obstructed 2. Clean outlet
3. Low speed fuel screw setting incorrect 3. Adjust screw
4. Starter valve not fully closed 4. Adjust valve
5. Float height incorrect 5. Adjust float height
Problem: Engine idles poorly
Condition Remedy
1. Valve clearance out of adjustment 1. Adjust clearance
2. Valve seating poor 2. Replace - service seats - valves
3. Valve guides defective 3. Replace guides
4. Rocker arms - arm shaft worn 4. Replace arms - shafts
5. Magneto defective 5. Replace magneto
6. CDI unit defective 6. Replace CDI unit
7. Spark plug fouled - gap too wide 7. Adjust gap - replace plug
8. Ignition coil defective 8. Replace ignition coil
9. Float out of adjustment 9. Adjust float height
10. Jets obstructed 10. Clean jets
11. Pilot screw setting improper 11. Adjust pilot screw
Here is a good link to read - not your machine but a lot of Q&A
http://www.dfn.com/benkaren/jetfaq.html
Old Jun 7, 2007 | 12:54 PM
nucca's Avatar
Starts and idles fine. just low on power until high rpms. I will check out the link. thanks
Old Aug 15, 2007 | 09:37 PM
leoj12's Avatar
I have the exact same problem. I cleaned the acrb twice, checked the diaphragm seems to be ok. When I give gas the slide doesn't move to the top even at full throttle it just move a little (I removed the boot intake to see the slide moving while I was giving gas) seems to be a vaccum problem but I can't find where is the problem
please need help
Old Aug 16, 2007 | 11:56 AM
nucca's Avatar
It sounds like we have the same problem. I also pulled off the air box and watched the slide. It barely moves at full throttle. I just adjusted the valves to see if it would help and it is still acting up. I am at a loss of where to start next. Let me know if you find out anything and I will do the same.
Old Aug 17, 2007 | 10:14 PM
leoj12's Avatar
Good news. I've found the problem!!! For the x times i took a parts my carb and I removed the black piece on the right side of the carb (see pictures below) This is the vacuum system that lift the slide. I've found out that the small black diaphragm was not moving freely (the black diaphgragm on the top). I removed it and I cleaned the small hole where it slide in and the hole that connect with the inside of the carb. I used carb cleaner to cleaned it. I also changed the O ring that goes around the orange diaphragm (the one at the bottom) just to make sure the seal was good. I also cleanded all the small holes in the black piece. I've put the carb back on my bike start it and the slide was moving up like it is supposed to move. I tried my bike and the POWER was back!!!!!!!!! It is pulling like it was when it was new. I pretty sure you have the same problem. Try that and let me know
Old Aug 21, 2007 | 01:28 PM
nucca's Avatar
Which O ring did you replace? The one on the side?
Old Aug 24, 2007 | 09:25 PM
leoj12's Avatar
The one around the orange diaphragm.
Old Sep 18, 2007 | 11:07 AM
nucca's Avatar
Thanks for your help. I found the problem. The top part of the accelerator pump cover was broken. I made a pipe to fit into the cover and go into the carb and all of the power is back.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
