high comp piston
Old Jun 20, 2007 | 04:43 PM
JoeDanger660's Avatar
Default high comp piston
i just got a 13 to 1 high comp cp piston, should i change the rod? if so whose is the strongest/best? besides that what else should i get to make sure this motor runs good and strong every race?
Old Jun 20, 2007 | 05:34 PM
Fulltiltrider's Avatar
make sure you get race gas (65bucks for 5 gallon) or you wont be going fast for long
Old Jun 24, 2007 | 08:38 PM
maddog56's Avatar
New rod is certainly recommended for high compression/high rpm, large bore builds. Best chromoly rod is Barker's but for the price of a new rod and install you can get a whole hotrods stock stroke crank.
For a little less than twice the price you can get into the 4mm stroker cranks.
C12 is up to 85 bucks per 5 gallon can here.
Old Jun 25, 2007 | 08:08 AM
WOW 85 bucks thats nuts. If I had to pay that I probably would switch to alky
exmotocrosser
Sep 13, 2019 06:12 AM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
