Warrior start problems
Old Jun 20, 2007 | 09:51 PM
mbogosia's Avatar
Default Warrior start problems
My warrior is having trouble starting. Neutral light comes on and when I press start I can hear a buzzing coming from a relay that is under the rear fender. Sometimes if I wiggle some of the battery or relay wires it starts but it is getting worse. I took all the wires off and cleaned everything with electrical cleaner and it still failed. I also checked a fuse that was back by the relay and it looks good. Could I simply need a new relay or do I have bigger problems like my start switch/starter?
Old Jun 20, 2007 | 10:05 PM
jdwanabe's Avatar
if you can narrow down where sound is coming from check for loose or "burnt" connection by looking into where wire enters relays or connector. Good luck
Old Jun 20, 2007 | 10:28 PM
mbogosia's Avatar
Okay, after looking at my chlymer manual it is the starter solenoid that is buzzing. All connections are clean. I might have to test it and check to see if it is good.
Old Jun 20, 2007 | 10:48 PM
mbogosia's Avatar
Dead Battery. LOL
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
