fuel mix ratio on a banshee
Just wondering what you guys with banshees run for mix ratio. I have a Clymer manual and it says to run 24:1. I think that I got a little too much oil in last time because it's smoking quite a bit.
Does he run 40:1 with synthetic or conventional? I really don't ride enough to have seasons. Is there a sure way to tell when your top end is getting worn out, Like excessive smoke and loss of power?
i think he uses conventinal. i use synthetic myself. and you will be able to tell big time if it is blown the power will be way down when you goose it.back in the day when i had my lt250r i used to run 32:1. if you run it at this level your pretty much not going to burn though top ends.
