Craptor Cutting out...
Old Jul 23, 2007 | 04:03 PM
velocyraptor's Avatar
Default Craptor Cutting out...
are the diaphragms from the carbs good?
Old Jul 23, 2007 | 04:04 PM
its not a rev limiter?
Old Jul 24, 2007 | 12:40 PM
skii0's Avatar
its sounds exactly like when your in reverse and the limiter kicks in only it dies...what exactly would i be looking at on the rev limiter?
Old Jul 24, 2007 | 02:21 PM
ds650ctracing's Avatar
It is flooding itself out, it is likely your imulsion tubes are worn & causing this. Replace both 1 for each carb.
Old Jul 24, 2007 | 02:27 PM
  #15
skii0's Avatar
haha and those would be....?
Old Jul 24, 2007 | 03:27 PM
  #16
Quad-Maniac's Avatar
Emulsion tubes are the needle jets. Worn out? Doubtful. Dirty? Sure.
Shouldn't be any of the RPM limiters because, as you said, "you can gun the throttle and it does what it normaly does(what it supposed to ha)". I have heard of a reverse limiter connection that was marginal, and it only lost contact with the swtich's connector at mid RPM due to vibration, so i'd still check, clean and tighten the reverse switch connector, just to eliminate it as an issue.
So, you are having a mid throttle issue, right? You say "started up the craptor today". How long had it sat previously? Was there ANY indication of similar issues before? Have you performed any modifiacations recently?
The pop from the carb could be backfires, indicating lean air/fuel ratio. A little more information will help in troubleshooting.
Good Luck!
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Elkaholic
Sep 6, 2015 02:44 PM
