banshee stiff throttle
Old Aug 4, 2007 | 10:50 PM
beaty's Avatar
Default banshee stiff throttle
the throttle on my banshee is pretty stiff i was wondering how i fix that without getting those retarted throttle extentions is there something i can get or if u guys have eny info on what u do i relize 2 carbs its gonna be stiff but the raptor has 2 and thats not even close to as stiff as mine
Old Aug 5, 2007 | 08:20 PM
beaty's Avatar
i took out the spring in the throttle box but that didnt help much eny suggetions would be nice thanks
Old Aug 5, 2007 | 08:58 PM
kawiking's Avatar
did you see if its binding up anywhere ?? do you still have the tores on it ?i know every shee ive had and rode is alot stiffer than any 4 stroke ive rode.my buddies shee is alot stiffer than mine.... ???? has it always been stiff ??
Old Aug 5, 2007 | 09:02 PM
beaty's Avatar
yeah tors is removed yeah but iv never had a proplem to silver lake when trying to run laps around the dune ur thumb starts to kill
Old Aug 5, 2007 | 09:26 PM
kawiking's Avatar
i just think thats a banshee throttle... my buddy put a honda throttle on his... i have a yfz throttle on my kfx(also a yfz carb ). . ive had 3 throttle's for my shee... they all felt diffrent ,but all kind of stiff.i have 34 mm pj's now and its still kind of stiff.
Old Aug 5, 2007 | 11:53 PM
beaty's Avatar
so just switch the throttle box and that should do it......its not to bad but i run with 700s and 450s and do laps around the dunes after a couple laps it starts to hurt alot
Old Aug 6, 2007 | 12:07 AM
kawiking's Avatar
well i hate to tell you to buy 1.... it may help it may not... do you still have your blaster...if so try switching those boxes and see ... mine isnt bad till i really ride awhile.. ive thought of getting a exstended thumb lever.. i pretty much just drag race my shee.
Old Aug 6, 2007 | 12:25 AM
beaty's Avatar
yeah i still got my shee my dad mostly rides the blaster so theres a twist throttle on it i just found the old throttle for my blaster ill look into it tomarrow ya i seen urs is more of a drag quad.....and i hated the throttle extension it does make it alot easyer but for jumping and stuff if sucks....it could proply do good to surve ur purpose of dragracing
Old Oct 25, 2007 | 05:18 AM
hugsgt's Avatar
i know this is an old post but i have the same problem with my thottle, after thinkin for a while about it, i came up with the idea of shortening the springs in the carbs a little at a time, this is where the problem is coming from,, too heavy of a spring for the slides, just remember to take a little at a time!!! and make sure they're even! good luck
Old Oct 25, 2007 | 10:14 AM
kawiking's Avatar
i ordered a lighter tension spring for my 34mm pj carbs from F.A.S.T (farm and sand toys)........... becareful cutting your spring !!! im not sure if jeff(F.A.S.T) sells a spring for stock carbs ....
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
