2001 yamaha warrior
Old Aug 20, 2007 | 11:30 AM
banshee.350's Avatar
Default 2001 yamaha warrior
my 01 warrior sputters and back fires when you give it gas. I unplugged the neutral switch(I think that is what it is called) on the clutch lever perch and pushed in the toggle on the wire and the engine runs fine. What is the function of this switch and how do you repair or defeat this. It seems to be an intermittent problem. Any help is appreciated
Old Aug 20, 2007 | 02:16 PM
lucasislight's Avatar
take the switch right off, it causes more problems than anything.
Old Aug 20, 2007 | 07:09 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
that's the parking brake switch, remove it completely, unplug the wires from the harness... 2 plug into each other than the 3rd hangs put a parking brake block off plate on the brake caliper and ditch the rest
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
