cooling a banshee
Old Aug 27, 2007 | 10:42 PM
03bansh33's Avatar
Default cooling a banshee
i have a 2003 Yamaha banshee and it gets a little hot when im not moving very fast is there something a can do 2 cool it better?
Old Aug 27, 2007 | 10:55 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
run synthetic oil, run engine ice, try a billet impeller from Pro Design, if that don't work try a new aftermarket radiator
Old Aug 28, 2007 | 02:12 PM
03bansh33's Avatar
thanks 4 the tips. i had planed on running the billet impeller i figured it would help me out.
Old Aug 28, 2007 | 03:20 PM
minnzilla's Avatar
Definatly get the impeller. Why they put a plastic one in is beyond me? I also run a larger radiator and it will still get hot if you are not pushing alot of air past the radiator.
Old Aug 28, 2007 | 03:22 PM
velocyraptor's Avatar
20 fin inline coolers help too
Old Aug 28, 2007 | 05:06 PM
Speedy2222's Avatar
the plastic impeller is fine if u are riding in <80 * conditions... but when u start getting higher up the engine needs a billet impeller.
Old Aug 28, 2007 | 07:05 PM
garyc660R's Avatar
The engine ice works great as mentioned.....just put the antifreeze back in for the winter time. Nothing helps keep a Banshee from overheating while idling for an extended period of time though. You can roll a new one off the showroom floor and it will be spitting coolant in 10 minutes idling.
Old Aug 28, 2007 | 10:08 PM
Doctorturbo's Avatar
GOT BOOST!
One more idea. Dump in 10% methanol in the fuel tank and jack up your jetting 10%. Cooler running engine and a tad bit more power. Win, win.
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
