A few Raptor questions
Old Sep 4, 2007 | 10:03 PM
Zickefoose's Avatar
Default A few Raptor questions
<div class="FTQUOTE"><begin quote>Originally posted by: zizard
also,check your tire pressure,that makes a big difference.I ride mainly sandy to hard pack dirt,I keep my rear tires at 3 to 3.5 lbs and my front at 3 lbs. That should help out the handling some what.</end quote></div>
Think I messed with tire pressures a bit already. But, I'll give it another try. Thank you.
Old Sep 12, 2007 | 01:35 PM
killakevbeastmode's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Zickefoose
<div class="FTQUOTE"><begin quote>Originally posted by: killakevbeastmode
Its not the quad. Its you.</end quote></div>
Well, thank you but everyone knows Raptors are top heavy and tons of tourqe for the weight. But I am getting better, unlike some I have not had mommy and daddy buy me a 4wheeler when I was younger to gain more exp. I finally can afford one on the messly $15 an hour Frito-Lay gives me. But I am getting better lol....
Oh and to add.... The damn Carbs fell off my bike last weekend. Could have been the West Virgina terrain and trails that did it. But, I tightend them back up and no problems so far.</end quote></div>
I wasnt knocking you, But for the record, I dont have a Mommy or Daddy, if that was directed towards me. I have worked my whole life, and I have rode for most of it as well, its not my fault you make what you make, you should keep your personal business out of it, its not a good look.
But on the other hand I was mearly stating a fact, it was my answer to your question, its not the quad, its you, if you know your machine you know what it can do, if you dont well.....You have enough body weight to keep it from tipping, try swinging your whole body in the opposite direction, control the machine dont let it control you, either that, or slow down, your not really racing it anyway right? so...be safe and save the other atvers a head ache from bans and less and less places to ride, cause beginners like you want ***** to the wall from the rip and end up getting seriously hurt, so please slow down, at least till you know your machine. Although, It does take a few bang ups to really know and respect it. Have fun, cheers.
Old Sep 14, 2007 | 12:33 PM
skramblr's Avatar
If the bike is not turning, look into this:
1) Bent tie rod or threads on tie rod end bent - make sure they are straight.
2) Wheel alignment - If the Toe-In is not correct and/or one of the tie rods has been tightened more than the other, it may not steer correctly. You can check by measuring the exposed threads on tie rod ends.
3) Pitman Arm Bent
Old Sep 18, 2007 | 08:19 PM
Mutch_17's Avatar
Get a Steering stablizer!!! or try different front tires or not so luggish rear tires!
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
