dead kodiak
Old Sep 8, 2007 | 11:43 AM
gruntski's Avatar
Default dead kodiak
can anyone help, i have a 2003 450 kodiak, I was playing in a mud hole, and my atv died. I could not start it, not even pull start worked, I have not lights on the dash, and blowing ignition fuses. Any ideal?
Old Sep 8, 2007 | 01:13 PM
Williebee's Avatar
Default dead kodiak
Let's see you were playing in a mud hole and the engine died and won't restart , no light's on dash and it's blowing ignition fuse's ? Was it just mud or was there water and mud in the hole you were playing in ; it's a short in the wiring somewhere causing the fuse to blow ! You will need to give the quad a good cleaning to start with , then let everything dry up before you start doing any trouble shooting ; but my bet is that you'll need to go over all the electrical system ! All the electrical connection's for mud and or water has gotten into a connector and is causing the short , so you'll have to start going over them one by one unplugging them ; cleaning out any mud from the connection's and after cleaning and drying them out use some Di -Electric Grease to fix the short ! I would start off from the battery cable's first then move on to tracing the wire's to each connection one at a time , this is where you need a good Service and Repair Shop manual ; there are site's that have the schematic's for the electrical system wiring diagram's www.bikebandit.com is one ! There are other site's with more detailed view's , but a shop manual would be my choice to begain with ; how ever maybe someone will jump in here that has had the same thing happen that you are having now ! I'm no expert whem it come's to the wiring on these quad's , but it has to be in the electrical circuit ; and i don't have that much experiense with Yamaha's only Honda,Suzuki and AC brand's ! This is just general info , so someone else jump in and give us a hand to help us with this problem ; and good luck gruntski on the fix and let me know how it goes i get emails when someone anser's a post i just wish i could be of more help ! ...................
Old Sep 8, 2007 | 02:30 PM
Traildad's Avatar
Default dead kodiak
It could also be problems with the wires. Check for problems with the insulation. It could be cracked or chafed allowing the wire to ground out.
Old Sep 8, 2007 | 05:45 PM
gruntski's Avatar
Default dead kodiak
thanks guys, i had every connection apart and dryied, all wires are looking good, I think it was to go to the shop,, [img]i/expressions/face-icon-small-sad.gif[/img],,
pgamboa
Dec 24, 2023 11:52 AM
YankeeRebel
Oct 6, 2015 06:44 AM
DM2015
Sep 7, 2015 10:36 AM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
