Grease Zerks
Old Sep 8, 2007 | 02:19 PM
gordie580's Avatar
Default Grease Zerks
I am trying to lacate all of the grease zerks on my ATV and I have only found 2 of them. The ones on the right and left rear axle. Does anyone know if there are others?
Old Sep 8, 2007 | 02:20 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
what quad do u have? there are usually 1 on each a arm, some on the swingarm, depends what u have
Old Sep 8, 2007 | 02:36 PM
gordie580's Avatar
I have an 07 700 FI, with about 700 miles on it.
Old Sep 8, 2007 | 02:45 PM
Speedy2222's Avatar
700 what?? raptor or grizzly?
Old Sep 8, 2007 | 02:53 PM
gordie580's Avatar
Grizzly
Old Sep 9, 2007 | 12:05 AM
Mud Hog's Avatar
How often do you need to add grease to your bike? I would figure they do that when you bring it in for routine maintenance.
Old Sep 9, 2007 | 12:16 AM
Speedy2222's Avatar
not usually.. i do mine before every major( day or more of CONSTANT riding) trip or once a month if i am just messin around... or if i am bored i pump till i know it's full( pressure on the pump handle) if u go through alot of water and mud, i'd grease it once every 2 weeks or more if u ride alot
in reality.. only YOU can tell when it needs it, after you do it for so long, you'll be able to tell when/ if something needs greased
Old Sep 9, 2007 | 12:20 AM
Mud Hog's Avatar
Don't you run the risk of busting the seals?
Old Sep 9, 2007 | 12:23 AM
Speedy2222's Avatar
not if u do it right, if you keep pumping and pumping and pumping u can... but if u have a feel for it.. you can tell when it's full... like on mine.. it will pump with little pressure then when it is full it gets stiff.. that's when i stop .. or sometimes u hear the seals crackle
Old Sep 9, 2007 | 09:26 AM
Mud Hog's Avatar
Do you use a specific grease or will a basic one do?
