99 Bear Tracker Rear Brake Drum 24mm nut STUCK!!!
Old Sep 8, 2007 | 08:11 PM
troutdog's Avatar
Default 99 Bear Tracker Rear Brake Drum 24mm nut STUCK!!!
I'm changeing the brakes on my 1999 Bear Tracker 250. The front brakes was OK. The rear,,,, one of the lug studs just spins around and around, So I tried to take the Tire and Drum off all in one. The center nut holding the drum is ON THERE!!. I even have a inpact tool,,, it won't move at all. I even tryed it if it were left handed threads and nothing. The nut looks fairly new and has NO dirt or grime on it.
What do I do to get it off? Thanks
Old Sep 10, 2007 | 04:18 PM
TrustKJV's Avatar
You should be able to take the nut off with an inpact. Try chocking the wheel so that it does not turn and try to break the nut loose with a long breaker bar. ( It is right handed thread ) Be careful not to let the socket come off the nut. Also check to make sure a piece of the cotter pin did not break off keeping the nut from turning.
Old Nov 28, 2007 | 01:48 AM
hiEnuff's Avatar
You should be able to get it off with a impact but you might have to find somebody you know that has a big compressor for more "umph" to get it off. I had the same problem. Went down the automotive shop and he popped it right off.
Old Nov 28, 2007 | 10:57 AM
STRAIGHTUPDAHILL's Avatar
you need a real impact....are you holding the socket the other direction while running it
Ean
Dec 19, 2022 08:48 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
timster911
Jul 13, 2015 01:57 PM
