1998 yamaha Banshee
Old Sep 13, 2007 | 02:40 PM
Nolovelost's Avatar
Default 1998 yamaha Banshee
i just reciently aquird a 1998 banshee and i cant seem to get it to revout i can fether it to get it to rev but thats it i know it is jetted. any suggestions on a cure.
Old Sep 13, 2007 | 04:55 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
You change the plugs?
Old Sep 13, 2007 | 05:13 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
the tosp of the plugs may be damaged/ loose and that will affect performance
Old Sep 13, 2007 | 11:41 PM
Squishy's Avatar
Check plugs. if one side runs hotter than the other, your carbs are out of sync. there are windows on the side of carbs. at wide open you will see a spot the apperrs. they should apper evenly. if off buy a mill, the carbs won't draw evenly. if not, adjust throttle cables at top of carb. don't blow this off. I know I have. are there any other mods then the jetting?
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
Slagpolaris
Sep 5, 2015 09:41 PM
