atf or oil for banshee ?????????
Old Sep 15, 2007 | 01:57 AM
greenskin's Avatar
Default atf or oil for banshee ?????????
hi i heard so many things on this for a banshee
what to use for crank case oil
i heard you can you atomatic transmission fliud has any really used this out there and riden hard for long period of times???????????????
and the other was non synthic oils wich iran all the times but
who has any comments here would help
thanks
Old Sep 15, 2007 | 03:25 AM
DesertViper's Avatar
We used Motul 15w50 synthetic in our Banshee. Make sure the oil is suitable for use with a wet clutch. If it says ATV specific or Motorcycle specific it is ok to use. Or if you are using a car motor oil to avoid paying the extra cost of "ATV specific" marketing be sure that it does not have friction modifiers in the oil, because they can make the clutch slip.
DV
Old Sep 15, 2007 | 09:05 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
you can run type F ATF in banshee's or i run 90 weight AMSOIL gear oil for quads
Old Sep 15, 2007 | 11:45 AM
skramblr's Avatar
Why would you run ATF?
Old Sep 15, 2007 | 12:15 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: skramblr
Why would you run ATF?</end quote></div>
Because on a 2 stroke engine the crank and transmission are separated by seals. The oil mixed with the fuel lubricates your crank bearing, so the lubricant in the lower engine cases are really just doing the transmissin and clutch. I used to run ATF in some of my 2 strokes, but I didn't notice any difference. There were some local raceres here who swore by using the B&M Trickshift, but that stuff was $8 a quart!
Old Sep 15, 2007 | 12:22 PM
Speedy2222's Avatar
you won't notice a difference between ATF and regular gear lube.. until you get into bigger power( 60+ HP) however.. some people swear by ATF and that it is the best stuff out there.. IMO i wouldn't run it in a trail quad.. also, ATF is liek $3 a quiart at advanced auto parts
Old Sep 15, 2007 | 02:18 PM
skramblr's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
Because on a 2 stroke engines the crank and transmission are separated by seals. The oil mixed with the fuel lubricates your crank bearing, so the lubricant in the lower engine cases are really just doing the transmissin and clutch. I used to run ATF in some of my 2 strokes, but I didn't notice any difference. There were some local raceres here who swore by using the B&M Trickshift, but that stuff was $8 a quart!</end quote></div>
Thanks for the education... Now I know.
Old Sep 16, 2007 | 11:54 AM
greenskin's Avatar
ok speedy but after 60 plus horsepower what do you think works better, i hvae pretty close to 60 i think mines a 406 vitto kit tommey pipes cool head,boost bootel,and reeds to match
Old Sep 16, 2007 | 12:18 PM
Speedy2222's Avatar
ATF i would use
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
