No Start Problem
Old Sep 26, 2007 | 07:10 PM
jayt555's Avatar
Default No Start Problem
I Have an 01 Warrior that won't start.I checked the batt.it's good.I replaced the starter relay,nothing.I cleaned and checked all connections and checked the fuse.I can start it by jumping the starter relay, my neutral light and headlights don't come on, but the reverse light works.What could it be???? I hate to toss $$ at it to get it going. Any ideas? Thanks in advance.
Old Sep 26, 2007 | 11:14 PM
atvgreg's Avatar
Have you or any one on the form got a wiring diagram I can look at????
Old Sep 26, 2007 | 11:25 PM
atvgreg's Avatar
Hi mate found a wiring diagram, looks like the earth from both the lights and the starter motor run from the switch, the left handle bar switch check your earth the black wire should go to earth, if it does I suspect there is a problem with it try running a new wire thats about all I can see let me know if that dont work
Old Sep 27, 2007 | 12:52 AM
jayt555's Avatar
When you say earth i think you mean a ground wire right? Any chance on sending me a copy of the wiring diagram? Thanks Jay
Old Sep 27, 2007 | 08:43 AM
atvgreg's Avatar
Yer but where do you want me to send it to????
Old Sep 27, 2007 | 08:57 AM
atvgreg's Avatar
I have up loaded the wiring diagram to my host for you see link below, i don't know cause i have never owned a warrior before but i would imagine all the highlighted earths(grounds) will all be connected maybe in the headlight. This is the one I would suspect to be faulty, as the lights wouldn't work and also the starter solenoid wouldn't be earthed through the switch. Let me know if I am wrong I will study it again without the 8 cans of larger [img]i/expressions/face-icon-small-smile.gif[/img]
Wiring Diagram
Old Sep 28, 2007 | 02:01 PM
jayt555's Avatar
Anyone else have any ideas? Thanks for the help ATVGreg!!
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
