98 Big Bear 4X4: need help w/ U Joint
Old Oct 26, 2007 | 04:58 PM
BOSSC351's Avatar
Default 98 Big Bear 4X4: need help w/ U Joint
My 98 has a grease fitting on the front U joint but not the rear. Thought about drilling one of the rear bearing caps and installing a fitting. However, when looking at the joint I am not so sure there is a tunnel through the body for the grease to flow through. Does anyone here know??
Old Oct 26, 2007 | 09:40 PM
Traildad's Avatar
Well I don't know about yours, but I do know that some U joints are not meant to be greased. It could be that one of them is not original equipment. Is it possible that the zerk fitting is missing? If it doesn't have a place to put a zerk in it, I wouldn't try to add one.
Old Oct 27, 2007 | 02:29 AM
BOSSC351's Avatar
I appreciate the reply.
I looked all over the joint and no hole. I really do not want to yank the drive shaft to change joints but I also do not want to ruin what life it current one has either.
Old Oct 27, 2007 | 03:35 AM
Traildad's Avatar
If it was made to NOT be greased then you can't hurt it by not greasing it. If you ever take the shaft off, put in a grease able joint then. Otherwise just wait until it goes out.
Old Oct 27, 2007 | 12:21 PM
TLC's Avatar
TLC
The original U joints are sealed and you do not grease them most replacement U joints have a fitting. I would not bother with it, but when the time comes get replacement parts with fittings if available.
Old Oct 27, 2007 | 01:33 PM
STRAIGHTUPDAHILL's Avatar
get a needle adapter for your grease gun
Old Oct 27, 2007 | 11:19 PM
BOSSC351's Avatar
How will the needle adaptor help? There are no fittings or holes.
The only reason I thought about drilling a hole is because it is done in automotive applications. Yes its sealed but I am afraid mud and water is getting in there plus they are most likely OEM.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
