Maintenance questions, and other questions
Alright, I got my raptor 350 a couple weeks ago, everything is stock except for the HMF slip on.
I am just looking for things that I shoud look for that may need changing? Hopfully today, I will be getting a air filter, UNI or TWIN? Also, whats the differnece between the regular replacement filters and the HIGH flow kits, are they worth the money? Do they increase power by a lot, which is the best one for the money?
I was also going to get a spark plug, oil filter, and oil. Are there any other things I should pick up?
Also, has anyone put new handle bars on there raptor 350's? Im thinking of replacing mine, can anyone recommended a good set of decently price handle bars?
I will also be getting new tires and such, I will be posting pictures in my gallery some time in the future =]
Spark Plug, just use the NGK D8EA
UNI or Twin filters are fine. the high flow kits enable you to run without the lid. It comes with an adapter flange that bolts onto your stock airbox, then lets you clamp the filter to that flange vs. the stock setup where the lid holds the filter in place these kits would probably help you out since you have a pipe. probably need to rejet while you're at it though
handlebar? all depends on your size and what fits you. renthal, pro-tapers, tag, are all good brands. I replaced mine with "FLY" and they suck. barely wide enough to fit all the controls on.
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
