any body use water wetter
Old Nov 18, 2007 | 09:44 AM
330's Avatar
330
Default any body use water wetter
any body use water wetter does it work any side affects thanks
Old Nov 18, 2007 | 09:51 AM
DesertYFZ450's Avatar
don't use water wetter, get Engine Ice, it works better, from what i hear water wetter is more corrosive and bad for your motor! ive heard only good about Engine Ice! supposed to drop temps by 30-50 degrees
Old Nov 18, 2007 | 12:55 PM
v2rider's Avatar
I have a new jug of engine ice i will sell for 10 bucks, as i only use Amsoil now. But you probably are about 15 hrs away!
Old Nov 18, 2007 | 06:49 PM
330's Avatar
330
when you say you use amsoil are you speaking of oil if so does it make it run cooler
Old Nov 18, 2007 | 06:55 PM
v2rider's Avatar
Amsoil antifreeze. I use amsoil oil in my crankcase, and diffs. I pretty much use amsoil for whatever i can.
Old Nov 21, 2007 | 11:18 PM
moomba99's Avatar
DO NOT USE WATTER WETTER...Very corrosive. The engine ice is Great. I missed what machine you are running. If its a banshee and your looking to run cooler, Try a billet water pump, and while your at it....Pro circuit makes a really cool water pump cover called "e-z drain" It allows you to drain your anti freeze through a screw tapped in the water pump cover without having to remove the hose every time getting anti-freeze everywhere. Easy mod, takes about an hour to complete and the water pump keeps the temp down pretty well!
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
awer1968
Sep 8, 2015 11:02 AM
