Banshee gearing
Old Nov 25, 2007 | 04:47 PM
inkram's Avatar
Default Banshee gearing
I have 21" tall Super Swamper rear tires, to get more bottom end should i get a smaller front sprocket, or a larger one?
Old Nov 25, 2007 | 10:00 PM
recon99's Avatar
Making the front sprocket smaller will make your gearing lower, giving you a little more bottom end. Keep in mind though that every time you drop a tooth smaller on the front sprocket you lose about 5 mph of top speed (assuming the gearing was allowing you to wind out in high gear before the change)
Old Nov 26, 2007 | 12:34 AM
inkram's Avatar
Thanks, even with the taller tires it still gets up and goes. I'll just keep it with the stock gearing, because where I ride I need that top end in some places. thanks for the help.
Kaleb_00
Jun 1, 2016 09:15 AM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
