raptor 660
Old Nov 28, 2007 | 07:30 PM
badass raptor's Avatar
Default raptor 660
what do i need to take to the machine shop to install a stoker crank and a 105mm piston also does the timming chang
Old Nov 28, 2007 | 07:49 PM
yotatrailrunner's Avatar
Default raptor 660
If you are doing the assembly yourself then you should only need to take the cylinder and the engine cases to the machine shop if not take the entire engine to them. The Cam timing will not change when you bore and stroke the engine. Cam timing can only be changed by either a adjustable cam gear, skip a tooth on the chain or a offset keyway on the crank gear.
Old Nov 28, 2007 | 08:59 PM
Default raptor 660
what do they do to the case
Old Nov 28, 2007 | 11:47 PM
Default raptor 660
If it is like the big bore kit on the wolverine 450 they will have to clearance the case for the new sleeve and maybe clearance it for the new crank.
Old Nov 30, 2007 | 12:24 AM
maddog56's Avatar
Default raptor 660
You'll need the cases, the cylinder, the new sleeve, and the piston with rings. The cylinder will need to be bored to accept the new sleeve. Then the sleeve is installed and the sleeve has to be bore and honed to get the proper piston to cylinder wall clearances and the rings will need to be filed for the right ring gap. Then (or this can take place after the sleeve install) the cases need to be bored to accept the larger sleeve.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
