How do you do your compression tests??
Old Dec 10, 2007 | 12:47 PM
toddmh's Avatar
Default How do you do your compression tests??
I did a compression test on my 03 wolverine and it came up 90-95 psi..So I was like time for a ring job because the manual says it should be around 110-120 psi..I called my local dealer and talked to one of their tech guys and asked me if I had the throttle wide open when I did the test?I did not,he says thats why you are at 90-95psi.Test again wile holding your throttle wide open,that is the way Yamaha determines their specs..So I did what he said and it was right around 120psi..Can anyone here confirm this way of testing,wile the Yamaha tech says its the way to do it,the manual says nothing about the throttle that I have seen??
Old Dec 10, 2007 | 03:07 PM
ctateusa1's Avatar
well did you have the atv warmed up?
To get a proper reading on the compression it needs to be warmed up so that you can have the rings expanded so they are meeting the cylinder walls properly. But I do hold the throttle wide open as that is the way most manufacturers do check compression.
Old Dec 10, 2007 | 04:38 PM
toddmh's Avatar
yeah she was pretty warm..I did that test after a bunch of carb adjustments tests..Thanks for the confirm on the throttle..
Old Dec 11, 2007 | 11:24 PM
HiLi_Psyclez's Avatar
ya i always do it throttle open. Alot of times i tried it both ways and honestly never seen a difference in psi, but sometimes it does. all the manufacturers specs say throttle open, so best to do it that way...
Old Dec 13, 2007 | 04:25 PM
hondabuster's Avatar
Yep, the throttle must be held wide open, or you wont get the proper reading. All the text books and service manuals say it as well.
Old Dec 16, 2007 | 05:08 PM
maddog56's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: HiLi_Psyclez
ya i always do it throttle open. Alot of times i tried it both ways and honestly never seen a difference in psi, but sometimes it does. all the manufacturers specs say throttle open, so best to do it that way...</end quote></div>
I too have noticed that it doesn't always make a significant difference in the readings.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
