STIFF THROTTLE CABLE
Old Dec 11, 2007 | 06:43 PM
fastquad02blaster's Avatar
Default STIFF THROTTLE CABLE
Just wondering if anybody else has probs with sluggish throttle cables in the winter time? Is there anything that I can lube it up with. Maybe spray somthing down it from the top. I haven't done anything to it yet. I'm waiting on experienced advice. Thanx.
Old Dec 11, 2007 | 11:18 PM
HiLi_Psyclez's Avatar
you can spray some silicone down the cable. I had a problem w/ mine a few times when it would get wet and be freezing out would kinda come back to idle slow( when i pinned it it kinda wanted to stay there lol) i took the throttle off put the little hose on the spray can and **** some silicone down the cable worked it in and repeated a few times. Havent had a problem since.
I did all my bikes while i was at it, clutch, throttle, and reverse if equipped. Good idea to keep em lubed. Makes for easier pull and longer life also
Old Dec 16, 2007 | 06:02 PM
Thanks. I just didn't want to spray something down it that would screw up the liner and destroy my cable.
Old Dec 17, 2007 | 11:00 AM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
YUP, water gets in and freezes. WD-40 Use it religioously prior to going out for a ride. It chases water out as well. I don't know how, but it works.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
Slagpolaris
Sep 5, 2015 09:41 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
