warror parking brake to remove
Old Dec 15, 2007 | 02:33 PM
ridingr6's Avatar
Default warror parking brake to remove
I am removing the parking brake off my 02 warrior and need some info in doing the jod right the first time. please help. thanks
Old Dec 15, 2007 | 04:37 PM
jimmies440's Avatar
i just did that to mine well you will need a block off $10 and a clutch lever with post $15 all you do is remove you stock lever (throw away) remove the 2bolts that hokd the park brake on the calipier (keep) remove cable and assembly (throw away) then install block off use the stock bolts and clutch lever the wire that was hooked up to stock lever assembly just unplug it and you are ready to go hope i helped jimmie
Old Dec 15, 2007 | 05:27 PM
ridingr6's Avatar
thanks the only other question would be about the wiring. does that have somthing to do with the rev limiter and just unhooking it the rev limiter still work?
Old Dec 18, 2007 | 10:28 PM
jimmies440's Avatar
the rev limiter will still work fine all the wiring dose is cuts it back to 1500rpm when the park brake is on but you wont need that sence you dont have a park brake
Old Dec 18, 2007 | 10:41 PM
STRAIGHTUPDAHILL's Avatar
how you going to keep it from falling off the trailer now...lol
Old Dec 19, 2007 | 10:48 PM
jimmies440's Avatar
i never think of stuff like that till its to late
toonces
Aug 5, 2015 05:55 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
