How do I change 1997 Blaster transmission fluid?
Sorry I have a noob question. I am changing my Blasters crankcase oil. The window where you measure how much fluid goes. Now do I use that window to measure with the 4 wheeler running or not running?
Also, I am using Bel Ray gear saver.
Thanks for the help.
Not running, you can warm it up and check it, if you dont plan on draining the old oil out of there which you should. Just make sure its on level ground. Belray gear saver is good stuff.
tank10rnk
Aug 10, 2015 08:19 PM
atv, blaster, change, changing, fluid, oil, put, tranmission, tranny, trans, transmision, transmissiom, transmission, wha, yamaha
