36mm BSR carb on a Wolverine 450
Old Jan 19, 2008 | 02:30 AM
derrelw's Avatar
Default 36mm BSR carb on a Wolverine 450
$300.00 brand new. Would the extra few mm make enough difference in performance to make it worth it on my bike? I think it should be a bolt on mod. Yes or no.
Old Jan 19, 2008 | 10:17 AM
ctateusa1's Avatar
What you need to do is check and see if the floatbowl has a lower drain than the stock one because if it is too low it will hit the starter. For the most part it will be a bolt on mod if you dont have to change the throttle cable but you will probably have to change the jetting. what is the 36mm bsr off of? I think I am going to try and get a used yz125 or yz250 carb to put on mine, I will probably have to mod the float bowl to clear the starter. And change jetting to get the a/f mix right.
Old Jan 19, 2008 | 11:45 AM
derrelw's Avatar
It's the factory Raptor 350 carb it even comes with a 142.5 main jet and it's set up for a thumb throttle. I'm just not sure it will make much of a difference.
Old Jan 19, 2008 | 05:09 PM
ctateusa1's Avatar
not sure if you try it out though let me know
Old Jan 20, 2008 | 04:48 PM
yotatrailrunner's Avatar
that carb has the same throttle cable housing and the same fuel bowl as the 33mm carb on the wolverine. only thing i have not checked it to see if were the hoses clamp to it are the same size. I bouhgt a 36mm BSR off a LTZ400 and the main body is the same but the throttle housing and the float bowl are completey different
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
