Strange Problem
Old Jan 23, 2008 | 05:28 PM
MortisFK's Avatar
Default Strange Problem
My Mother-In-Law has a 2001 BigBear 400. She's using it to plow her driveway. She starts it up and lets it warm up, and it runs fine up and down the driveway as many times as she needs to do it. But if she is out when it starts getting dark, if she turns on the headlight, the engine will sputter and die within 30 seconds. And then she said it seems the gear shift is locked and she has to work really hard to get it back to neutral. Then she'll turn off the lights, and it will start right back up and run fine again. What they heck is causing this?
Old Jan 23, 2008 | 11:59 PM
Hebs's Avatar
Never heard that one before... You can check all of the wires and fuses to make sure nothing obvious stands out, but you might have to take it in to the shop to get it looked at. Be sure to let us know what the fix was.
Old Jan 24, 2008 | 12:18 AM
ctateusa1's Avatar
possibly too much drain on the battery causing it to die between the headlights and the winch operating the plow.
Just a possible suggestion
Old Jan 25, 2008 | 03:17 PM
imsam77's Avatar
the wires might be grounding out...maybe a slit in one or something...check the fuses and such like hebs said, when it's electrical it could be anything, maybe you might havta take it to a stealer
Big bousse
Sep 26, 2015 10:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Unzzy66
Jul 11, 2015 10:01 PM
