sounds like your floats are open try taping on the bowl with the back of a screwdriver. if that doesn't help then there must be some dirt in the needle seat. good luck
Its probably too crusty for tapping to work. Youll have to remove the carb, and clean the float needle and seat. Theres a piece of crud, preventing the needle/seat from shutting off the flow of gas.
