Real top speed of a Warrior.
Old Jan 15, 2001 | 08:36 PM
warrior3443's Avatar
I believe that the real top speed of a warrior is around 58 to 59. I think this because my '96 warrior is stock except for a uni filter, the tire pressure in the front was a little low, and i had a friend on the back. I am a smaller rider and my friend is average size. I had a truck following behind me and i was doing 55. I figure that if a had more air in the front tires and was by myself that it would have went a little faster.
Old Jan 15, 2001 | 09:03 PM
HondaManMyers's Avatar
That is a very inacurate way to tell speed. There are just too many factors that can change. The truck speedo could even be off a little and you can't just guess speeds.
Old Jan 15, 2001 | 10:09 PM
I know it isnt the actual top speed. Even tho it may be inacurate, i dont think it can be REAL far off. I understand the the speedo in the truck may be off a little but that is a pretty common answer i have heard. a lot of people has said that the warrior will run in the mid to upper 50's. i believe that the warrior will run in the upper 50's.
Old Jan 15, 2001 | 10:14 PM
660R01's Avatar
Even though that isn't the most accurate way to measure speed..I think you are pretty close, I know I read a shootout that said it topped out at 56. But it is probably anywhere from 56-59..
Old Jan 16, 2001 | 12:20 AM
14mins's Avatar
This summer a guy i was riding with had a new warrior,stock. I have a modded lakota that goes 58.6 mph according to my gps. the warrior was faster than mine all around. the elevation around here is 800 feet above sea level. I don't know how much elevation has to do with it though. The warrior was faster..
Old Jan 16, 2001 | 11:33 PM
AtvOffroad's Avatar
If your Warrior is bone stock I believe it's around 50-55 mph. Add a couple modifications into it and it will go faster. I added a pipe, 14 tooth sprocket, and drilled holes in my airbox, and the local police department clocked me at 67 mph :-(.
Old Jan 21, 2001 | 11:32 PM
killerb's Avatar
ha..now your stretching it
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
01ssls1
Sep 22, 2015 06:50 AM
black_thunder
Sep 6, 2015 04:41 PM
