Hotcam for raptor
Old Mar 14, 2008 | 06:44 PM
  #21
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
Default Hotcam for raptor
please video the double back flip attempt LOL
Old Mar 14, 2008 | 07:40 PM
  #22
dewey_700r's Avatar
yeah im filming it for sure im already starting the engineering on the ramp
Old Mar 15, 2008 | 12:22 PM
  #23
skramblr's Avatar
You never mentioned what mods you have...
Nor how much you want to spend...
So it's difficult to make recommendations.
Adding a hotcam is pointless without other engine mods.
If you are bone stock, try K&N, open airbox, aftermarket exhaust (header & slip-on), and a new CDI. That's the basic start.
If you want addidional mods, it all depends on how far you want to go. $$ and reliability. Make sure you look at the whole picture, not just upgrade only a piston or cam or porting or.....
Old Mar 16, 2008 | 08:05 PM
  #24
ich4bdm's Avatar
i asked for a 700 raptor not a 660 and i have my mods listed. i'm asking if stage 2 will make a difference or if i have to get a higher comp. piston?
Old Mar 16, 2008 | 08:40 PM
  #25
skramblr's Avatar
Whoops. Dewey stepped into your thread (no mods listed).
Changing the Cam is what creates the higher compression. If you increase compression, the stock piston may not last long (depending on how high you go). So putting a new piston in at the same time makes the most sense.
Old Mar 16, 2008 | 08:54 PM
  #26
dewey_700r's Avatar
sorry little guy we got off track there
Old Mar 16, 2008 | 11:10 PM
  #27
DuneMe's Avatar
For the Raptor 700. . . first it's the 3-mod (Pipes, Air Filter and Power Commander).
After that, the six mod is the next step. . . (3-mods + Dynateck + the +2TB + Stage 2 Hot Cam). At this point the head hasn't been pulled yet.
After that, look at port work and a high compression piston or big-bore.
How much power do you want / need?
Old Mar 16, 2008 | 11:12 PM
  #28
ich4bdm's Avatar
thanx skramblr
Old Mar 25, 2008 | 09:52 AM
  #29
king_kval's Avatar
Ihave a stage 2 hotcam,with wiseco high compression piston on my 04 660 raptor,with a stock pipe and jetting and it made a huge difference in power all around.dont forget to get the valve spring kit.
Old Mar 25, 2008 | 10:30 PM
  #30
DuneMe's Avatar
Most guys with the Raptor 700 and the Hot Cam II are running it with the stock springs. I agree, springs are a conservative way to go but, most run the stock springs with that cam.
