Hotcam for raptor
Old Mar 25, 2008 | 10:42 PM
  #31
king_kval's Avatar
Default Hotcam for raptor
well if they are running stock springs it wont last.if you dont believe me then try it.YOUR LOSS.just trying to help.
Old Mar 26, 2008 | 02:46 AM
  #32
DuneMe's Avatar
king - not trying to stir anything. . . do a search - on other forums there are a ton of guys running the HC II without changing the springs. The thing you have to remember is this cam / head is nothing like the 660 cam/head. The 700 head is totally different and there are a bunch of guys running the cam without changing springs and a number of the big builders that are saying it is fine.
All that being said, it can't hurt to change the springs. Just not something that is needed based on everything I've read.
Old Mar 26, 2008 | 04:28 AM
  #33
king_kval's Avatar
sorry i thought we were talking about the 660 but i would still do stiffer springs for better throttle response.
Old Mar 27, 2008 | 01:10 AM
  #34
DuneMe's Avatar
The valve springs will protect you from floating a valve. Never heard of it helping throttle response???
Old Mar 27, 2008 | 01:13 AM
  #35
bigned1904's Avatar
you should check out x2 cams. i think they are alot better than a stage 2 hotcam
Old Mar 27, 2008 | 02:17 AM
  #36
DuneMe's Avatar
The MegaCycle X2 Cam is much more aggressive. Great for the big-bores!
You absolutely need springs with this cam. You also may need to make some modifications for clearance from what I've heard.
I've heard the X2 cam may not give you as much if you are looking for a drop-in cam. Once you build your bike I understand you'll see more of an increase (i.e. big-bore, stroke, etc.)
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
