HELP me FAST wITH my 350 warrior
Old 03-09-2008, 09:33 PM
wwarriorrider350's Avatar
Default HELP me FAST wITH my 350 warrior
what do you mean Put it on slow charge and charge it over night?
i was going to take cables and hook the battary to my car battary and charge it like that?
Old 03-09-2008, 09:43 PM
Drifter463's Avatar
Don't do that...
Go to WalMart and get a battery charger... $30 if that...
Old 03-09-2008, 10:03 PM
okay
but alot of people told me that i could charge it with my car?
what could happen if i did that
do i need a special battary charger?
and are you sure i need a battary charger? the battary is brand new i mean i just took it out of the box about 2 days ago
i havnt rode with it yet
i will most likley get a battary charger, all my friends told me my battary was dead too so im sure thats the problem
Old 03-09-2008, 10:11 PM
QWODER's Avatar
does that model warrior have a rope start on it?If it does it should have a handle on the left side of motor that you can pull and start it.If it does then just use that to start it then ride it a while to charge up battery then see if the electric start will work.It would be best to charge the battery up with a charger though.
  #15
Old 03-09-2008, 10:13 PM
Drifter463's Avatar
A car / truck battery has too many cranking Amps... The ATV battery could blow up on you...
You can pull start it and ride it if it is a standard ATV... (can't do it with an auto trans) Just ride it for 3 or 4 hours...
  #16
Old 03-09-2008, 10:15 PM
the guy i got it off of told me i need to get a battary with alot of cranking Amps.
by pull starting it do you mean push start?
  #17
Old 03-09-2008, 10:20 PM
Drifter463's Avatar
Yes push / pull start it...
As for the Amps think of it as power... How much power do you think it would take to turn over a car motor and how much do you think it would it take to turn over a ATV motor...
ATV is a lot less...
  #18
Old 03-09-2008, 10:35 PM
tomarrow i will hook it up to my friends trx450 and pull it down the road and start it like that. do you think thats a good idea?
i started it like that before but it kept shutting off because there was water in the gas tank
  #19
Old 03-09-2008, 10:49 PM
Drifter463's Avatar
Yes that would work... Just ride it for a few hours...
  #20
Old 03-09-2008, 11:01 PM
great
i really hope the only problem is the battary
Quick Reply: HELP me FAST wITH my 350 warrior
