cool head, v force reeds, or exhaust for my shee
Old Mar 24, 2008 | 12:46 AM
bigned1904's Avatar
Default cool head, v force reeds, or exhaust for my shee
why fmf pipes over toomy t5s?
Old Mar 24, 2008 | 06:50 PM
exrider91's Avatar
oooh thats what they do for a port job i know for 4 stroke motors the heads get ported.the reason for fmf not tommys is every banshee i've seen around here had fmfs and i used fmf pipes before on other bikes so im sticking with them.
Old Mar 24, 2008 | 10:48 PM
bigned1904's Avatar
well i whould highly recomend toomy t-5s over fmf. they make more power and sound better imo
Old May 31, 2009 | 08:40 PM
yamaha 4 life's Avatar
hey how much would it cost to port a banshee and could a local dealer? also milled head could a dealership do that too?
Old Jun 2, 2009 | 10:54 PM
  #15
superyfz350's Avatar
depends if the dealer has a machine shop. haha
Dont wast your money on vforce reeds unless your going to port the hell out of the motor and put bigger carbs on it. I am looking for a cool head myself because they have inerchangible domes so i can run 93 octane during the week, and change them out to run 110 at the drag track on the weekend. I found a nice set of used Bills pipes for $100 on craigslist. I ported the jugs myself for the cost of the dremel ($30)
All together i plan on spending this...
100 for pipes
150 for used cool head and domes
120 for rear tires
300 for pistons and boreing
30 for dremel
all together about $700 into the engine
Beware that I was extra carefull with the port job i did, and that i measured both ports with calipers to be shure they were identical.
For you, just find a nice set of used pipes, increase the compression by milling the head or getting a cool head, rejet the carb (if stock carbs, jet up to between 220-235) then if you have stock tires, your going to need a nice set of aftermarket ones
Old Nov 8, 2009 | 02:49 PM
  #16
hey i have an 01 banshee it is ported, has race carbs, k&n filter, fmf pipes and soon to be vforce 3 reeds, are the reeds going to give me power or did i just waste my money... ? a cuple other questions are withh it beat 660 and 700 raptors? thanks -cj
Old Nov 8, 2009 | 04:39 PM
  #17
cherokee99's Avatar
reeds dont buy you power, waste of $'s in my opinion. in some model dirtbikes with poor stock reeds, aftermarket reeds can give you a better throttle response. but generally the gain in power is all in your head. save your money for an engine mod, and buy a set of stock reeds.
Old Nov 9, 2009 | 07:22 AM
  #18
keljose's Avatar
Milling the head will be approx 80$. Yes, nobody will know what you have either.
Are you planning on getting porting done anytime in the future? if so i would recomend getting t5's. They go good with stock and ported engines mid-top end power. Fmf sst pipes, or toomey t6 are also good for mostly stock engines.
You can find a check online for a set of used pipes. There are always some listen under "for sale" on www.bansheehq.com or ebay.
Good luck.
Old Nov 10, 2009 | 03:27 PM
  #19
91Warrior357's Avatar
get some good pipes like toomey t5s then take it from there...milled head, +4 stator plate, vforce3 reeds,k&n or uni pod filters, Tors removal, trail porting,boring with wiseco pro lites,bigger carbs,noss or cool head,domes.... list goes on lol, would always start it off with the big 3, pipes,filter,jetting then go from there.
zach1106
Jul 31, 2015 01:55 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
