What jetting
Old Mar 21, 2008 | 09:09 PM
  #21
pmcc37's Avatar
Default What jetting
I thought that, dumb question, but how do you adjust the air fuel mixture? Is it the little screw on the bottom of the carb?
If so do they make a screw that comes out the bottom that you can twist? I know they do for other bikes, just not sure bout the warrior..
Old Mar 21, 2008 | 09:21 PM
  #22
toddmh's Avatar
not the idol screw,if it the same as the wolverine,It's a screw that is set in cast tube at the bottom of the carb..It might have a cap on it..Go all the way in then 2 1/2 turns out to start..
Old Mar 21, 2008 | 09:33 PM
  #23
pmcc37's Avatar
yeah thats what i thought, its not caped off, takes a lil flathead screwdriver, no easy way to adjust it, except pull the cab every time.
Old Mar 21, 2008 | 09:48 PM
  #24
toddmh's Avatar
yeah I have a tiny little screwdriver to get at mine..
Old Mar 21, 2008 | 09:55 PM
  #25
pmcc37's Avatar
I've been searching for one that you can just turn, i guess its a new thing, for the yfz ect... MSR, Tusk and somebody else makes one, but none for the warrior. May have to take it ppart and see what I can make....
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
