YAMAHA WARRIOR 360
Old Mar 22, 2008 | 09:47 PM
Octane2079's Avatar
Default YAMAHA WARRIOR 360
I don't see 72mph happening unless you get a cam and some stiffer valve springs as your going to need something that is going to give you better peak HP number because with stock gearing your going to have to wind the **** out of it to get anywhere near 72mph.
Old Mar 22, 2008 | 10:20 PM
DeathValleyReaper's Avatar
it was stripped down and blueprinted all the way through. he has a ton of money rapped up in it and i dont know what else he has in it but i know it was only bored .30 over. im sure he re-did everything.
Old Mar 22, 2008 | 11:24 PM
Jasonp's Avatar
A stock warrior will do around 63 mph with 22" tires. Now with the 20's on the back that is going to slow you down. You might get like 60 or so but you'll be reving the ***** out of it. You can't really blueprint a warrior engine, it's really not all that high tech. Pretty slow reving low tech, 4 stroke that is ment to last. But believe what you want. The most a stock stroke warrior engine will be around 30 hp all decked out.
Old Mar 23, 2008 | 12:38 AM
WARRIOR360's Avatar
i'm sorry about my list on the top i forgot to add a dyno jet kit
when i posted it would that help my warrior any?
Old Mar 23, 2008 | 12:43 AM
  #15
WARRIOR360's Avatar
my step dad and i are putting my warrior that is a 360cc after we bored it out back together but we still have to port and polish the head. All of the things i
LIsted are the things i want to get for it, for sure within the next two months.
do you guys see anything on my list that i should get a stage 1 hot cam instead
of
Old Mar 23, 2008 | 01:59 AM
  #16
QWODER's Avatar
How did you get a 360 motor?Is that a big bore kit you put in it or did you just bore it and called it a 360?
Old Mar 23, 2008 | 03:58 AM
  #17
Patches3489's Avatar
go with stage 2 hot cam its not that much more than a stock cam
Old Mar 23, 2008 | 04:34 AM
  #18
toddmh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: QWODER
How did you get a 360 motor?Is that a big bore kit you put in it or did you just bore it and called it a 360?</end quote></div>
I think this kid has more hot airthen one of those...well..Hot-air balloons
Old Mar 23, 2008 | 10:13 AM
  #19
WARRIOR360's Avatar
wow QWODER are you dumb or something of course it is
a big bore kit why would I pay like 1000 bucks for a used
engine only 10cc more than mine
Old Mar 23, 2008 | 10:27 AM
  #20
QWODER's Avatar
man you've lost me here.Where did you write that you payed $1000 for anything?How old are you?
