2000 yamaha beartracker with 250 cc
i just bought a 2000 Yamaha bear tracker for 400 and the person i bought it from stated that oil and fuel are mixed in the breather and i cant seem to figure out why it is mixing in breather and what i can do to fix it.
thanks any info is greatly appreciated.
00beartracker I think the problem is that most people here don't know what your asking. Obviously you realize that the Beartracker is a 4 stroke so your not talking about oil and gas mixtures.
Are you talking about blow-by causing oil to accumulate in the air intake? If so it could be a compression/ring problem.
Could you be more specific.
the guy i bought it from just told me that it does get oil and gas in the breather element so i take it that it is a ring issue and that really sucks.thanks for the reply head now i get to gut motor and start over lucky me.
Does the ATV run good? We had a few ATVs with oil in the air box and it turned out to be either the oil level was to high or it gather from a tip over or steep hill climbing and descending type riding. The crakcase vent line blows oil in the air box.
i removed the drain plug for the crankcase and the oil was full of gas and also the piston was ceased in the cylinder i have taken the atv to a shop to have them pull the motor and check it all the way out and let me know what i am looking at to get it fixed. and thanks for all the replies to this post.
Njrider1230
Jul 29, 2023 05:16 AM
tank10rnk
Aug 10, 2015 08:19 PM
