07 yfz ?
Old Apr 18, 2008 | 10:42 PM
francis03's Avatar
Default 07 yfz ?
I have a quick question. Is there two separate drain plugs for the oil? Also is there two diffrent types of oil I need for both of the capartments.
Old Apr 18, 2008 | 10:58 PM
bberck's Avatar
Default 07 yfz ?
Yes to one and no to the other
You have a drain on the crankcase and one on the reservoir but they both take the same oil.
Old Apr 19, 2008 | 09:23 AM
francis03's Avatar
Default 07 yfz ?
okay thank you.
Old Apr 19, 2008 | 09:43 AM
klier's Avatar
Default 07 yfz ?
Both are 12mm. The Oil Tank takes about 1.64 quarts (1 quart and an extra 605ml), and the crankcase takes .31 quarts (293.4ml)
Old Apr 19, 2008 | 03:33 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default 07 yfz ?
Anyone have a trick to share? It's a pain in the ars taking that plastic skid plate off the belly to prevent oil from draining all in it.
Old May 19, 2008 | 05:45 PM
klier's Avatar
Default 07 yfz ?
I replaced my stock plastic skid plates off and replaced them with PRM Aluminum Skids that have a drain hole already drilled in. You can drill your own hole in the stock plastic skids as well.
Old May 19, 2008 | 06:00 PM
Koopa's Avatar
Default 07 yfz ?
Thanks klier. Planned on getting the drill out. Just wanted make sure I wasn't missing something. Another stupid design on yamaha's part.
Old May 19, 2008 | 06:56 PM
toddmh's Avatar
Default 07 yfz ?
If you trail ride on your YFZ atleast get a good swing arm skid,and some A arm skids,will save you lots of bucks in the long run..The belly skid does not take impacts like the other two do..
Old May 20, 2008 | 09:00 AM
Hebs's Avatar
Default 07 yfz ?
<div class="FTQUOTE"><begin quote>Originally posted by: toddmh
If you trail ride on your YFZ atleast get a good swing arm skid,and some A arm skids,will save you lots of bucks in the long run..The belly skid does not take impacts like the other two do..</end quote></div>
Actually the belly takes just as much punishment depending on the ruts you're riding thru... I would go belly and swinger skids first... and then the a-arms...
