question on Blaster Mods
I have a 99 Blaster Stock. Wondering if I should add one or two teeth to front sproket. Any other Ideas to get the maching faster. I dont want to spend much $. It feels like it has more power than speed.
the biggest front sproket u can get is just One tooth bigger "14" Sence your blaster is STOCK i wouldnt put it on there unless u have 18in rear tires. The cheapest way to make a 2 stroke go faster is a PIPE! and that isnt cheap sometimes
yeah, I would agree that a pipe and a silencer would give you the extra roost that your looking for. You dont really want to change your front sprocket gear ratio because you are bone stock and dont have any extra after market power to work with. You could go down a tooth, but that will make your quad slower but with more torque. Pipe and silencer did the trick for me and it was worth the 300 bucks because it woke up the bottom end nicely.
Logan Collins
Sep 5, 2015 08:03 PM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
