Tire Plys??
Old May 2, 2008 | 05:51 PM
adavis17's Avatar
Default Tire Plys??
This is probably a stupid question but I was wondering what the difference was between 4 and 6 ply ties. Is that just the thickness and how resistance they are to puncture???
Thanks
Old May 2, 2008 | 06:15 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default Tire Plys??
<div class="FTQUOTE"><begin quote>Originally posted by: adavis17
This is probably a stupid question but I was wondering what the difference was between 4 and 6 ply ties....
Thanks</end quote></div>
2 Plys!
J/k yes you are right. This applies to automotive tires also.
Old May 2, 2008 | 10:21 PM
Raptor450's Avatar
Default Tire Plys??
Yep, the more plys, the more puncture resistant they are. But usually the more plys, the heavier they are. The ideal trail tire is 6 ply but lightweight, like the Holeshot GNCC. The Holeshot HD's are also 6 ply, but very heavy. The Holeshot MX (motocross) is 2 ply, very lightweight, but not very puncture resistant, therefore good for (who would've guessed) - motcross!
Old May 3, 2008 | 04:34 AM
viper5's Avatar
Default Tire Plys??
If you do trail riding go with the 6 ply tires. Even if you do get a flat they are so thick you can ride back on them and they just look low when there's no air in them. That sure beats killing the rim riding back on a flat 2 ply. I never even killed a 6 ply riding it flat just plugged it when I got back and it aired right up
Old May 3, 2008 | 12:35 PM
COTU's Avatar
Default Tire Plys??
Not sure it applies here, but in the auto world there is also a ply "rated" system. Some tires will say "#" ply "rated" when they may be constructed with a different amount. I'm sure this is due to the use of different types of materials which may be stronger, lighter, thicker, or etc. I am not sure of the tests used to provide "rated" amount of plies.
Old May 4, 2008 | 12:01 PM
embler's Avatar
Default Tire Plys??
in automotive speak, the more plies, the more load they can hold.
Old May 10, 2008 | 07:21 PM
COTU's Avatar
Default Tire Plys??
Ok, when talking about bias ply tires, the construction of the tire gets stronger (higher load rating) with each addition ply added to the tire. When going to a radial tire, the same is not true, therefore radial constructed tires have ply rated designation to compare its load rating relative to a bias ply tire. And yes, I have seen ATV radial tires with the "ply rated" designation.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
