air filter oil
Old 05-07-2008, 07:26 PM
330's Avatar
330
330 is offline
Default air filter oil
does anyone use regular motor oil on their foam air filter filter is still stock i got some spray on filter oil but it is so tacky i believe it will stop the filter up is there any difference in oem and aftermarket thanks travis
Old 05-07-2008, 10:01 PM
embler's Avatar
its suppose to be tacky. that's its job, to trap dust and dirt. better the filter than your motor. engine oil would do nothing to help the filter. a good alternative that isn't too tacky is marvel mystery oil. I've used it when I didn't have the right filter oil and it works good.
Old 05-08-2008, 03:43 PM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 330
does anyone use regular motor oil on their foam air filter filter is still stock i got some spray on filter oil but it is so tacky i believe it will stop the filter up is there any difference in oem and aftermarket thanks travis</end quote></div>
First off Regular motor oil Stinks.... literally and functionally... I use Spectro Foam Filter Oil for my stock air filter. Stuff works great! a 1 QT bottle last quite a while...
Old 05-08-2008, 09:06 PM
jflib74's Avatar
Thats a big 10-4 spectro filter oil is great I put my filter in a big gallon ziplock baggy and dump in the oil and mush it all around saves a lot of mess on the hands. I use white wall cleaner and a hose to clean off the old dirty filter and redo it.
cswiger
Polaris Side by Sides
12
10-05-2015 03:34 PM
Nosniborpapa
09-12-2015 05:54 PM
Steeldon
09-09-2015 09:38 AM
black798
09-09-2015 07:42 AM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Quick Reply: air filter oil
