Big Problem Grizzly 600
Old May 14, 2008 | 06:28 PM
Grizzly600TX's Avatar
Default Big Problem Grizzly 600
well im working on my friends grizzly 600. its been sitting for a while so im cleaning it up and stuff. well it has a peculiar problem.... ok so there is a tube that connects from the bottom of the motor and goes back up to the intake. ok well when it idles and you rev it it shoots like gas/oil mixture back into the intake through the tube, i think its something really bad. hopefully you guys can help me out
Old May 14, 2008 | 10:52 PM
gncc450r's Avatar
One of my buddies has a 600 and for him has been nothing but trouble. He had the same problem with the oil in the intake.
Old May 15, 2008 | 08:27 AM
Hebs's Avatar
if it's the tube I think you're talking about... It's typically used to bleed off excess moisture/steam that's inside the engine. (like the water that seperates from your oil after it's been sitting for a while) When you're in off camber situations there are instances where a little oil can make it's way to the airbox... but it's usually minimal... It almost sounds like you have too much oil in the bike... Try changing it, and verify exactly how much is suppose to go back in... See if that fixes your problem...
Old May 15, 2008 | 05:57 PM
alright. ill check the oil level and possibly change it. ill let yall know if that fixes the problem
Old May 19, 2008 | 02:56 PM
Hebs's Avatar
verdict?
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
hondarider1234
Jul 21, 2015 11:53 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
