2005 yamaha raptor 350 no spark
my raptor 350 has no spark, ive checked all the connections and checked for power with a voltmeter. there is volts coming from the stator going to the cdi box but nothing going from the cdi box to the coil. i had the coil tested and they said it was good. could anyone tell me what it could possibly be? i really dont want to buy a cdi box unless i have to.
ID bet 100$ on it that it's the PICKUP COIL it's bolted by the stator go to http://www.rickystator.com/cat...fo.php?products_id=147 ITS RICKY STATOR THE GURU OF STATOR'S AND OTHER ELECTRIC PARTS i had the same issue with my 05 rap and it was the problem.. GOOD LUCK
Im 99% sure it is my first guess was the cdi box too then a buddy helped me out and come to find out that part is a pretty regular go out item. Let me know how it goes.. please email me if ya like xtaceice@aol.com
well i have one more question for u, how do i get the case off, lol, i took the one cover off and i can see a bolt attacted to what i assume is the crank, but how do i get the case off because i took all the bolts on the case off but it wont fit over that..
The part and stator is on the side of the motor with<~~~~~~~~ the plastic cover all you have to do is take off all the lil bolts and maybe tap the case with a rubber hammer TAKE ALL THE BOLTS OUT go here and look at the schematic of the case http://www.bikebandit.com/hous...aptor-350-2005/o/m8635 <~~copy and paste ok and go here and look at part 6 see the lil piece coming off the stator thats your part thats bad all you have to do when you get it is unhook your battery <~IMPORTANT and clip the wires there's only two color coded dont worry this is REALLY EASY I promise you so dont start stressing before you get your part like i did on a scale on 1 too 10 1 being the easiest this is a 2 at best. Ok now go here and look at the lil piece under part 6 and you will see what ya need to do.. http://www.bikebandit.com/hous...aptor-350-2005/o/m8635
No prob man and yea thats how mine did it ran perrrfect then one day I got it out rode it 4 like 2-3 min's and died wouldnt hit a lick, then a month or two latter a buddy wanted to look at it and said it was that part and replaced it and bam back in action...[img]i/expressions/face-icon-small-happy.gif[/img] AND HAS BEEN GREAT SINCE..
