Banshee Power Up KIt
Old Jan 25, 2001 | 06:07 PM
joey1's Avatar
Does anybody know if you can bore out or port the cylinders? I e-mailed FMF but they dont seem to want to answer. I cant give up my 420's power and torque.
Old Jan 26, 2001 | 05:21 AM
tntbanshee's Avatar
Many fully modified 350's should be putting out 60hp, the trick would be to get a wide powerband like powervalve cylinders usually produce. At $1800.00 retail plus at least $350.00 for the recommended 35mm carbs that would be $2150.00. That's if you can install it by yourself. Doing a topend is not that complex. There are ALOT of places that could build you a 60 hp Banshee with a great powerband for quite a bit less money.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
